06-16-2014 02:15 AM - edited 06-16-2014 02:26 AM
Hi all,
I want to show a lot of settings by using cluster controls that can be expanded and collapsed. While my program works, I am wondering if there is a more elegant way to reference sibling clusters in the same pane.
Right now, when the control "expand all" is clicked,this is the chain that I use to turn on the visiblity of controls in sibling clusters in the same pane.
Another problem is that I don't have control of the cluster index. Regardless of "set tabbing order", "settings 2" comes before "settings".
Regards, Jin Kai
06-16-2014 06:07 AM - edited 06-16-2014 06:13 AM
Dear Jinkai,
I believe I can present a solution for your second (other) problem.
I stripped away the main control panel and reversed the order of the remaining panels. Now, you can also avoid checking for the i>0; that #0-panel is not present in the outher for-loop anymore. Cheers,
edit: of course, you have to start with a different than zero vertical position:
