10-15-2014 02:03 AM
You can download DAQ example in which UI is also there. Also that depend on your and your user requirement
10-15-2014 02:13 AM
Thank you for you advise. I understand the principle. But I want to carry on my UI design according to a specific theme(like military, industry). Are there some documents or demo or control suite?
10-15-2014 02:28 AM
got that but actually there is no theme. All themes are modified as per your requirement
10-15-2014 02:34 AM - edited 10-15-2014 02:59 AM
I have some personal guidelines:
1. Use SYSTEM controllers/indicators
2. Disable default right click menu. Make your own instead.
3. Make your own run time menu
4. Change graph background colour. (transparent?)
5. Change Window title. from main.vi to something that make sens
6. Have a sensible minimun panel size
7. Make it resizable
8. Do NOT use that modern red STOP button. Ref 1.
9. Hide toolbar when running
Im not saying that this is the blue print, but hopefully it will help you on your way.
10-15-2014 03:02 AM
Thank you. It will help a lot.
10-15-2014 03:02 AM
Oh, yes. Do you know good resources for DAQ example? I am a freshman, so maybe bother you to recommend some
