03-26-2016 10:23 PM
03-27-2016 02:14 AM
Hi,Nathand,
Sorry for the mistake I made in the text. The IP address of the DSP and PC are different(10.110.41.56/10.110.41.57). I have connected the DSP and PC directly through RJ45 socket via a net cable. When I send data from the DSP to PC via UDP, I can see those data on Wireshark. I have not embedded ICMP protocol in DSP yet. However, I wonder the Wireshark thing somehow validates the connectivity of the DSP and PC.
03-27-2016 09:41 AM
Directly, as in a single cable?
Did you use an ethernet crossover cable?
03-27-2016 07:51 PM
Yes, I connected the DSP and PC through a crossover cable via RJ45 socket.
03-28-2016 03:29 AM
Thank you, guys, the problem has been solved. It was the IP checksum that caused the problem. Wireshark does not validate the IP checksum check under default mode. Therefore, I did not manage to notice the wrong byte order of the IP checksum. Now everything seems to be working fine. Anyway, thank you guys for your kindly help!
