04-25-2015 05:26 AM
I'm writing here asking for help in UDP connection between RT and Host.
When I run Simple UDP NI example that sends data between two ports on the localhost everything works fine. But when I move Sender vi to RT target I get 59 error (LabVIEW: The network is down, unreachable, or has been reset.).
It seems to be a problem with IP address. Does anyone has any idea what I do wrong? I attach the code: Simple UDP Receiver und My Computer, and Simple UDP Sender under the target.
I found this post: https://lavag.org/topic/16630-network-discovery-via-udp/ but it seems that the author tried to establish UDP connection between sender and receiver located (both) on RT target, while I try to write from RT to the PC.
Thank you for your time
04-28-2015 04:47 AM
Hi Riv,
I would suggest you start from the following example ( it also uses myRIO with an UDP connection 😞
https://decibel.ni.com/content/docs/DOC-42180
