UDP Multicast
Jeff,
I'm runnng labview 2009 on both machines.  I did not modify the examples.  Thanks for thinking about this.
Message 11 of 15
(1,380 Views)
I did run the UDP multicast VIs at home and successfully broadcast some messages. I don't recall which computers I used so I can't say what the OS'es were. Why do you have to use multicast? Are you writing a client for a existing multicast server? If you are writing both the client and the server, I highly recommend the subscriber pattern. It worked well for me for the original problem that I posted and a multiple test system status monitoring program that I wrote later.
Message 12 of 15
(1,366 Views)
Yes, I am writing a client for an existing multicast server.  This is why I have no choice and must use multicast.  My IT support discovered a corrupted registry for the firewall on the PC that I was running the example multicast server VI on.  The firewall may have been restrictive.  I have not gone back and repeated the example client/server example, but I am able to receive multicast from the pre-existing multicast server.  This was my ultimate goal all along, so life is good.  Thanks to everyone.
Message 13 of 15
(1,362 Views)
hi sir, can you please sen the UDP code to me for reference - rambefrank@gmail.com
Message 14 of 15
(1,276 Views)
Duplicate request!
Rolf Kalbermatter
My Blog
Message 15 of 15
(1,268 Views)
