02-21-2007 10:51 AM
02-21-2007 11:01 AM
On the Functions Pallette:
Numeric/Conversion/To Long Integer
02-21-2007 11:05 AM
02-21-2007 11:09 AM
I have already tried that but doesn't work you can see the red flag in the input, in LV7.1 I could connect immediately the result of the substraction to the index of the arraysubset without any troubles.
Do you know how I can solve this issue?
02-21-2007 11:13 AM
Althought there is no broken wire my indictor DATABUILD UP does not display any lines, but if I connect a control I32 it is working, but I need the value coming frome the SFR adress which is in U8 format.
As I said before I didn't have this problem in LV7.1.that is strange
02-21-2007 11:36 AM
02-21-2007 11:52 AM
Hi Benio,
As Dave points out, the values may not be what you may expect for values of the U8-127 if the values are less than 127. If you are aware of this then disregard this post. If you re not then view the post attachment for an illustration. as a not or a quick test you can change the constant "127" representation to I32 and see if that works for you.
02-22-2007 02:59 AM
02-22-2007 04:58 AM
02-22-2007 07:43 AM
