05-11-2010 06:23 AM
I would not post this here if I had found a solution after extensive googling. Indeed I am surprised I could not find anyone else apparently had the same problems.
I have managed to setup LabVIEW for Linux 8.6 on an OpenSUSE 11.0 Gnome desktop (Dell Optiplex) and a Mandriva 2009.1 KDE4 laptop (Fujitsu). LabVIEW runs reasonably well in both cases, including VISA and drivers.
The problems I have are:
05-27-2010 05:29 AM
Really nobody has a clue on how to solve problem 2 above? I went as far as installing OpenSUSE 11.0 on my laptop as well, beside Mandriva, in order to be able to run labview on my laptop. It didn't go too well there either, stuck with NIKAL kernel module loading problem, with exact same distribution (11.0) and kernel (2.6.25.20-0.7-default) which works fine on my desktop. As I have spent considerable amount of time trying to fix the NIKAL problem before (I succeeded in Mandriva, never did in OpenSUSE) I think I will just forget about it this time.
So a clue on how to fix that annoying problem on Mandriva would still be appreciated 🙂 Thanks.
09-30-2010 01:30 AM
Hi
I know it is too late to give a solution but in case someone in the future who may face the problem and may stumble upon this post like I did, may find the solution to problem 1.
- On OpenSUSE 11.0 --> the keyboard input often gets "blocked", mostly when working on LV block diagram but sometimes on the front panel as well. I simply cannot input anything into LV from keyboard when this happens, while the keyboard works normally for other applications. I have tried to unplug and replug, change keyboard, etc. The only thing that seems to work *sometimes* is changing to front panel (or block diagram if I am on the front panel) by using the mouse, double-click on an empty region and start typing. This will cause only one character to appear and after that the "label" will be terminated as if Enter key was pressed. By doing this I can normally get the keyboard back, but other times I found no better choice than restarting LabVIEW. Thishappens quite often but haven't figured out how to trigger it.
I am using Labview 8 on Open Suse 10.3. Even I was facing a similar problem and it occurred after installing some international font, A new application SKIM was started in the startup. After i quit this application the problem was resolved.
Regards
Javed
