12-23-2014 11:37 AM
i am trying to run the "Opening a New VI from a Template " tutorial and it mentions
"3. From the Create New list, select VI»From Template»Tutorial (Getting Started)»
Generate and Display. This template VI generates and displays a signal."
i can not find "Tutorial (Getting Started)»Generate and Display" in the list of VI's after selecting NEW. where am i going wrong
12-23-2014 11:51 AM
What version of LabVIEW are you using?
I find that vi in LabVIEW 2013 sp1 at the top tool bar: File>>New...>>VI(folder)>>From Template(folder)>>Tutorial (Getting Started)(folder)
Hope this helps
12-23-2014 11:54 AM
File->New...->
In the Simulated group you can see the Generate and Display. If you dont have this, which LV are you running? This picture is from 2013.
/Y
12-23-2014 11:55 AM
Did you expand the "from Template" section?
(Not sure if this is needed, but do you have DAQmx installed?)
12-23-2014 07:52 PM
Hi ,
i am using 2014
i do not see the Tutorial (Getting Started) in my VI's
12-23-2014 08:05 PM
Yes, you are right. I cannot see it in 2014. I'll investigate.
12-23-2014 08:19 PM
however if you create new VI from >>Simulated>> Generate and Display it seems to behave as you would expect the Tutorial VI to behave, i started it this afternoon following the rest of instructions from the LabVIEW Getting Started pdf, and it seems to work.
12-29-2014 12:54 PM
Just to close the loop on this, the Getting Started with LabVIEW manual was deprecated in LabVIEW 2014. Because of this, we removed the New... templates that were used alongside this manual.
All getting started material related to LabVIEW is now available here: http://www.ni.com/getting-started/
12-29-2014 08:35 PM
thanks to all for responding, i think i am now on the right track
