Turning a C program into a dll with Bloodshed
I am having difficulties trying to, using the Bloodshed compiler to turn a simple C program into a dynamic link library. Is there, if Bloodshed is not easy to do so, something FREE that will easily create .dll's? I seem to be stuck at the part of somehow threading the Code and telling the compiler to turn it into a .dll. I am ok to step 5, chapter 2, (2-11), on Calling External Code in the LabVIEW Bookshelf under help. I am trying to use a Call Library Function. Is there a simple way of just wrapping these C codes and just pushing save as .dll?
Brian
(2,708 Views)
Hi Brian,
Bloodshed is not listed as one of the supported compilers for compiling shared libraries. For a Windows platform, we have the Microsoft Visual C++ IDE listed as a compiler that NI uses to test out compatibility. However, if you are looking for a free compiler, I would suggest downloading the GNU compiler, GCC http://gcc.gnu.org.
Kileen
(2,690 Views)
So as you say gcc is supported, bloodshed is too because it's just an IDE, which uses gcc as compiler. So it's "just" a question of correct parameters for gcc and I think you can pass any options to gcc you want from bloodshed.
So long,
Carsten
PS: Sorry, but I don't know how to create a Windows dll using gcc, but I think there should be documentation available somewhere. The standard configuration of bloodshed comes with the mingw gcc, so try starting at www.mingw.org.
(2,670 Views)
Well, it is OT, but anyway...
In my version of dev-C++ (4.9.8.7), I can create a new project, and select the "DLL" template from the Basic tab...
Just create a new dll project, and copy paste the code from the existing code.
Wiebe.
"CalTech" <x@no.email> wrote in message news:176244@exchange.ni.com...
I am having difficulties trying to, using the Bloodshed compiler to turn a simple C program into a dynamic link library. Is there, if Bloodshed is not easy to do so, something FREE that will easily create ..dll's? I seem to be stuck at the part of somehow threading the Code and telling the compiler to turn it into a .dll. I am ok to step 5, chapter 2, (2-11), on Calling External Code in the LabVIEW Bookshelf under help. I am trying to use a Call Library Function. Is there a simple way of just wrapping these C codes and just pushing save as ..dll?<br><br><br>Thanks,<br><br>Brian
(2,627 Views)
