03-08-2007 02:21 PM
03-08-2007 03:33 PM
08-04-2014 10:20 PM
Hopeless,
Would you (or anyone) save this vi as 7.1 and reply with it?
Greg
08-04-2014 10:28 PM - edited 08-04-2014 10:28 PM
That VI may be in version 8.2, but you don't want to use it. It uses ancient functions.
Use a VI that has a property node for the serial port line.
08-04-2014 11:53 PM
RavensFan, after some reading I understand how the DTR property node can switch pin 4 on/off on a 9-pin serial port. Sorry, I am looking for a similar solution for a USB port. I plan to buy the USB relay below. How could I go about turning it on and off?
Thanks for the reply!
-Greg
08-05-2014 12:55 AM
08-05-2014 08:29 AM
-Greg
As was said earlier, you can't do that with a USB port. You will need a device such as a DAQ device or the one you linked to. Another option is to get a USB/RS-232 adapter.
But the device you linked to should work once you find out in the instruction manual the method to communicate with it.
08-05-2014 10:12 AM
I understand. Thank you both.
-Greg
