Hello, I am trying to make a subVI that extracts parameters from a config file. I am getting stuck at the point where I am trying to save all the data into a cluster. I want to use a cluster because I have all sorts of data in my config file (ints, floats, strings, etc). I want to reduce the amount of code duplication and make the subVI easier to add parameters too. So Im looking to index through a cluster one control at a time and get the control label. Then with each label, I want to use the config VI's to load that specific key from the ASCII config file and save it to the corresponding control in the cluster. The cluster is a strict TypeDef defined in its own custom control. So my questions are:
1) Is there a way to index through a cluster one control at a time and save data to it.
2) Can it be done with minimal use of the property node. In some cases, there may be upwards of 100 parameters in my config file.
