01-02-2014 09:50 AM
I am running LabVIEW 2012 f5 and trying to connect to a built executable using the 2013 Descktop Execution toolkit.
Ideally I would like to do this on a remote machine with only the RunTime Installed, but I am having so many problem I thought I would start of on a local machine, with the full 2012
development installed.
* Firewalls are disabled.
* I can connect the DETT to the top level project in dev mode.
* Created a debug build executable. using this executable I can connect and run the executable in Trace mode from the dev environment using "Dubug Application"
But if I only run the executable then start the DETT I gat <LabVIEW>VI Server not found and a popup LabVIEW server access not enabled.
My labview ini file is below.
[SUB10-ATS-DEBUG]
server.app.propertiesEnabled=True
server.ole.enabled=True
server.tcp.acl="440000000900000001000000380000000001000000000000000000000000000000000000000000"
server.tcp.enabled=True
server.tcp.port=3368
server.tcp.paranoid=True
server.tcp.serviceName="+*"
server.vi.access=""
server.vi.callsEnabled=True
server.vi.propertiesEnabled=True
WebServer.TcpAccess="c+*"
WebServer.ViAccess="+*"
DebugServerEnabled=True
DebugServerWaitOnLaunch=False
I would be grateful for any help
01-02-2014 10:18 AM
OK,
I have jst played around some more and managed to get it working ....yippeeee
my new ini file looks like ---
[SUB10-ATS-DEBUG]
server.tcp.acl="310000000A000000010003110000000030000000000010000000000"
server.tcp.serviceName=""
server.vi.access="+*"
The key difference is the serve.vi.acess="+*" and adding in local host 127.0.0.1 into my VI server configuration.
