01-09-2016 11:45 AM
Just upgraded to LabVIEW 2015 and CompactRIO 15.0.
Also used the NI Update Service to install bug fixes for LabVIEW 2015 and CompactRIO Device Drivers.
I am attempting to add a target in LabVIEW from the 'Add targets and devices' window. I select "new target or device" and expand the sbRIO options. I see a bunch of targets, but unfortunately the sbRIO-9607 does not show up. It's just not listed.
Thoughts? When I get back in the office on Monday I will try a repair of the driver.
Best,
Dan
01-11-2016 06:32 AM
Now at the office with the hardware, I try to "discover an existing target(s) or device(s)"... when I expand Real-Time Single-Board RIO, I see:
"NI-sbRIO-9607-[serial number] (Link-local IP Address)
"This device is not supported by your LabVIEW environment."
That's bizarre because before I performed the updates recommended by NI Update Service, I was able to target code to this device and run it.
01-11-2016 06:42 AM
Well, this is embarrassing, but I'm sure I'm not the first and won't be the last to make this mistake.
I had accidentally opened LabVIEW 2014 SP1 instead of LabVIEW 2015.
Of course it works in LabVIEW 2015. Congratulations if you guessed this might be the problem.
