Truncate Long Paths bug?
Someone please clarify me if this is a bug. Pelase have a look at the below snapshot. The two path constants are respectively the same as that of the two on the right.
- Partha ( CLD until Oct 2024 🙂 )
(2,913 Views)
It looks like in the second path, it can't fit even the last part of the path ("find undocumented VIs in...") into the path constant because it's so long. Showing "...\..." is the next shortest thing it can display with the 'abbreviate paths' option set.
I wouldn't say this is a bug...it just looks a little strange but it's because the last part of the path is so long it doesn't fit so it goes to the 'minimum' path it can display:
(blog)
(2,895 Views)
Is 65 too long?! Smiley Indifferent
(2,886 Views)
To fit in that path constant, yes 🙂
(blog)
(2,870 Views)
