Eric,
Does your code work in the development enviroment? Are you using labview
6.0? If so see my post from yesterday "bug found with tab control" you
might be experiencing the same thing i found with the tab control. The NI
guy who replied told me to download 6.0.1 to fix it but there is a known
bug with that upgrade so you might not want to upgrade.
Good luck,
Jared
"Eric Poirier"
wrote:
>>I have an array of control with a button to set the default value of these>array.
I have correctly linked an reference to a method of reinitialize the>array.
But when I compile, the button does'nt work. I'm new user of labview>and
I need help to how make that work.
