09-19-2016 02:26 AM
Hi GerdW, yes, I'm reading the string from myRIO. But, I've also tried reading using the basic random number, the data is not getting in the spreadsheet as well.
09-19-2016 02:29 AM
Hi Jia,
again: the myRIO does NOT have access to your PCs harddrive!
You need to store the file on the myRIO harddisc (or flash drive) and copy it over to your PC! And you need to use a file path which is valid on your myRIO!
01-17-2017 08:17 AM
I have same problem, but when I change the path to flash drive like you said,it still doesn't work,
can you explain it more detail about the solution please.
thank you
01-17-2017 08:27 AM - edited 01-17-2017 08:28 AM
01-17-2017 08:39 AM
I use G:\ , it is in my flash drive. outside my PC harddrive.
01-17-2017 08:54 AM
Hi Awan,
as has been said several times before: a RT (RIO) target does NOT have access to any drive connected with your host computer!
You need to choose a file path available on your RT target - most probably something starting with "c:\"!
