Trouble getting array from Excel file
This will likely be a very stupid question, but is there anything I could be doing wrong when trying to get a 2D array from an Excel file? The file contains two columns of data which I want as a 2D array (or two 1D arrays) and having tried a couple of things I'm not getting anything up on my graph. The VI attached is a work in progress and has been hashed together from some other work (it will be used to control scanning mirrors).
Thanks in advance,
Ben
(3,202 Views)
Are you trying to read an actual Excel file ( .xls ) or a delimeted/spreadsheet text file?
(3,195 Views)
Hi Ben,
Could you please post the actual file that you are trying to read from or a representative one if that is not possible. Also could you send the actual file I/O code you are working on, which has been cut back to only the file I/O part. This will allow me to run the code and see your exact problem. I will then be able to advise on how to overcome the problem.
Best Regards,
Christian Hartshorne
NIUK
(3,175 Views)
The file is saved as a .csv file, I've tried saving it as a .xls but it hasn't made any difference. The file is generated using a fairly simple python code, with an example attached. I realise I'm probably missing something very obvious, so thank you for being patient!
Ben
(3,153 Views)
Your file is a CSV comma separated file.  The Read from Spreadsheet File has a default delimiter of a tab.
Wire a string constant with a comma into the delimiter input of the Read from Spreadsheet File and it will handle your CSV file correctly.
(3,128 Views)
Accepted by topic author bencarrick
Hi Ben,
I have found a Knowledge Base article which relates to your exact problem. I have linked this below.
Reading Microsof Excel Numeric Data into LabVIEW
Having followed the steps in the KB, I changed the file to a text (.txt) file and was then able to read the data successfully and plot it on the XY Graph using a modified version of your code that only contains the File I/O element. If you make the necessary changes to your data file and then reference it in the modified VI that I have attached, this will illustrate how you can read your data into LV.
I hope this helps.
Best Regards,
NIUK
Reading Microsoft Excel Numeric Data Into LabVIEW
(3,082 Views)
Thank you, changing the file type solved the problem!
(3,017 Views)
