02-13-2017 05:27 PM
Hi all,
I'm trying to find a way to trigger a specific code only once after the Time out event in the event structure. I have many events that are handled by that event structure, otherwise it would have been a lot easier. I'm aware of the producer and consumer structure but it's tedious and I think there is a better way in such situation? any help is appreciated, thanks.
Solved! Go to Solution.
02-13-2017 06:58 PM
Your question is a bit vague, without any code i cant give a lot of suggestions.If by once you mean only the first time the timeout case executes you could use first call and execute the section of code only on the first time the timeout case happens.
02-13-2017 07:07 PM
Exactly!!!. thanks for the info and sorry for my bad explanation .. good luck .
