Translate Visual Basic to Lab View
Hello Community,
I was wondering if you could help me translate some visual basic syntax to labview's formula node. I got most of it done just need a couple of lines to do the rest.
This is the original:
'{This procedure, called Prop, calculates the pressure, specific entropy, }
'{and internal energy given the temperature and specific volume. }
Public Sub PROP(T As Double, V As Double)
'{Variables are defined for this procedure. }
Dim S As Double, P As Double, U As Double
'{Additional variables are defined for this procedure. }
S = 0#
Dim RHO As Double, TERM1 As Double, TERM2 As Double, TERM3 As Double, TERM4 As Double
Dim TERM5 As Double, TERM6 As Double, TAU As Double, PSI As Double, DPSIDT As Double
Dim Q As Double, DQDRHO As Double, DQDTAU As Double
Dim I As Integer, J As Integer
'{ After values are initiated, the sumation terms in the property }
'{ equations are calculated using a DO loop. The first DO loop is }
'{ used to calculate terms for PSI and DPSIDT. The following DO }
'{ loops are used to calculate Q, DQDRHO, and DQDTAU. }
TAU = 1000 / T
RHO = 1 / V
TERM1 = 0#
TERM2 = 0#
For I = 1 To 6
TERM1 = C(I) / (Exp((I - 1#) * Log(TAU))) + TERM1
TERM2 = (I - 1#) * C(I) / (1000 * Exp((I - 2#) * Log(TAU))) + TERM2
Next I
PSI = (TERM1 + C(7) * Log(T) + C(8) * Log(T) / TAU)
DPSIDT = (TERM2 + C(7) / T + C(8) / 1000 + C(8) * Log(T) / 1000)
TERM3 = 0#
TERM5 = 0#
TERM6 = 0#
For J = 1 To 7
TERM1 = 0#
TERM2 = 0#
For I = 1 To 8
TERM1 = A(I, J) * (I - 1#) * (RHO - RHOA(J)) ^ (I - 2) + TERM1
TERM2 = A(I, J) * (RHO - RHOA(J)) ^ (I - 1) + TERM2
Next I '{FOR I}
TERM3 = (TAU - TAUA(J)) ^ (J - 2) * (TERM1 + Exp(-EC * RHO) * (-EC * (A(9, J) + A(10, J) * RHO) + A(10, J))) + TERM3
TERM4 = TERM2 + Exp(-EC * RHO) * (A(9, J) + A(10, J) * RHO)
TERM5 = (TAU - TAUA(J)) ^ (J - 2) * TERM4 + TERM5
If (J <> 2) Then TERM6 = (J - 2#) * (TAU - TAUA(J)) ^ (J - 3) * TERM4 + TERM6
Next J '{FOR J}
DQDRHO = (TAU - TAUC) * TERM3
DQDTAU = TERM5 + (TAU - TAUC) * TERM6
Q = (TAU - TAUC) * TERM5
P = RHO * R * T * (1 + RHO * Q + RHO ^ 2 * DQDRHO) * 1000
If (RHO > 0#) Then S = -DPSIDT - R * (Log(RHO) + RHO * Q - RHO * TAU * DQDTAU) + 3.1872
U = PSI - T * DPSIDT + R * T * RHO * TAU * DQDTAU - 0.47
G1 = S
G2 = P
G3 = U
End Sub
This is what I have:
S=0;
TAU = 1000 / T;
RHO = 1 / V;
TERM1 = 0;
TERM2 = 0;
int32 I;
for (I = 1 ; I<=6; I+=1)
TERM1 = C[I] / (exp((I - 1) * ln(TAU))) + TERM1;
TERM2 = (I - 1) * C[I] / (1000 * exp((I - 2) * ln(TAU))) + TERM2;
PSI = (TERM1 + C[7] * ln(T) + C[8] * ln(T) / TAU);
DPSIDT = (TERM2 + C[7] / T + C[8] / 1000 + C[8] * ln(T) / 1000);
TERM3 = 0;
TERM5 = 0;
TERM6 = 0;
int32 J;
for (J =1; J<=7; J+=1)
TERM1 = 0;
TERM2 = 0;
for (I = 1; I<=8; I+=1)
TERM1 = A[I][J] * (I - 1) * (RHO - RHOA[J]) **(I - 2) + TERM1;
TERM2 = A[I][J] * (RHO - RHOA[J]) **(I - 1) + TERM2;
TERM3 = (TAU - TAUA[J])**(J - 2) * (TERM1 + exp(-EC * RHO) * (-EC * (A[9][J] + A[10][J] * RHO) + A[10][J])) + TERM3;
TERM4 = TERM2 + exp(-EC * RHO) * (A[9][J] + A[10][J] * RHO);
TERM5 = (TAU - TAUA[J])**(J - 2) * TERM4 + TERM5;
if (J != 2)
TERM6 = (J - 2) * (TAU - TAUA[J]) **(J - 3) * TERM4 + TERM6;
DQDRHO = (TAU - TAUC) * TERM3;
DQDTAU = TERM5 + (TAU - TAUC) * TERM6;
Q = (TAU - TAUC) * TERM5;
P = RHO * R * T * (1 + RHO * Q + RHO ** 2 * DQDRHO) * 1000;
if (RHO > 0)
S = -DPSIDT - R * (ln(RHO) + RHO * Q - RHO * TAU * DQDTAU) + 3.1872;
U = PSI - T * DPSIDT + R * T * RHO * TAU * DQDTAU - 0.47;
G1 = S;
G2 = P;
G3 = U;
Some values are undefined but I have them in a serparate .vi file. Something is wrong because I get differnt values when comparing the values. Any help will be appreciated
(2,128 Views)
Can you post the LabVIEW code that you currently have? If yes, identify which version of LabVIEW you are using.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,084 Views)
The second part is the lab view code that I currently have.
S=0;
TAU = 1000 / T;
RHO = 1 / V;
TERM1 = 0;
TERM2 = 0;
int32 I;
TERM3 = 0;
TERM5 = 0;
TERM6 = 0;
int32 J;
TERM1 = 0;
TERM2 = 0;
if (J != 2)
if (RHO > 0)
G1 = S;
G2 = P;
G3 = U;
(2,055 Views)
Using 2011 32 bit
(2,043 Views)
