Tpi Net compatible with LabVIEW 7.0 ?
I designed drivers with LabVIEW 7.1 FDS for a remote instrument using the TpiNet library and the .NET Framework v1.1.
The operation was quite good.
After translating the same VI's to LabVIEW 7.0 PDS in order to provide executable applications to my customer, I couldn't run any of my programs.
After connection to the instrument, Labview 7.0 PDS sends the following error message :
"Error 1055 ... Invalid object reference"
the class which obviously fails under Labview 7.0 PDS is Connect in Tektronix.LogicAnalyser.TpiNet.ITlaSystem ;
Could anybody confirm this incompatibility between TpiNet and LabVIEW 7.0 ?
or propose any solution ?
thanks 😉
(2,167 Views)
I advise you to contact tektronix to know the compatibility with Labview 7.0.
Regards
(2,138 Views)
