12-25-2013 03:37 AM
I am really in the beginning of the learning LabvIEW. I am trying to control a power supply( Ametek XG
1500 ) via LabVIEW through USB cable. I have goggled several websites, but still do not have a clear idea
of how to implement such task. I downloaded COM drivers from www.programmablepower.com. Then, device and
my computer see the USB cable, but I do not have exact clue to make a good program to control power
supply.
I tried to make a program with NI-VISA with SCPI commands. Actually, I am not sure to write true
commands and I can not see the voltage or current value on the front panel. I have never write a program
to control any electronic device. Maybe, I can not see the basic step or not.
Firstly, I want to write a program which makes power on/off to the power supply. I do not know where
should I begin. Please any of you give me an offer to do this task.
Thank you.
Deniz
12-25-2013 06:01 AM
You can use the relay for turning PS on / off
12-25-2013 10:19 AM
There is of course, the IVI driver.
I don't understand at all why you would install a different com port driver than the one that comes from Ametek/Sorenesen. In any case, I did not use the IVI driver. I simply created my own using Tools>Instrumentation>Create Instrument Driver Project. Pretty simple for me - I did a basic driver in less than a day. I would suggest you look over the instrument driver tutorial (on main idnet page). The commands are well documented in the manual. Be sure to get the termination characters correct. I can't provide the code I wrote as it was for a customer but if you post what you have written with details on errors you get etc, I'll try to help.
11-13-2015 06:05 PM - edited 11-13-2015 06:09 PM
Hi Dennis
I have relevant question too.
I got stuff to work in NI-MAX using Visa Test Panel, i.e.
successfully querying commands like
*IDN?\r *ADR\s8\r OUTP:POW:STAT\sON\r OUTP:POW:STAT\sOFF\r
BUT
when I try to use same commands in LabVIEW using VISA blocks nothing happens. No error - nothing.
Any idea?
A.
P.S. I'm using Ametek XG300-5.6 one
11-13-2015 06:20 PM
11-13-2015 07:39 PM
And of course Dennis is correct. They end in \r, bu the constants are in normal display mode, which means the are being sent as a literal backslash and "r".
Also, the *RST command is missing any attempt at a termination character.
11-17-2015 02:40 PM
That was indeed the cause. Thanks
