Timestamp When Condition is Initially Met?
My VI currently displays the elapsed time since acquisition started. I want to keep the vi running, but have a second timer that stops when a condition is met- (when acceleration data surpasses a value).
I've tried using while loops where the condition met=true stops the loop and the value can be displayed (see attached image). However, this entire thing needs to be placed inside a second while loop in order to continuously acquire data. When I do this, the VI will run for one second then stop. I dont think it likes the nested while loops.
I have also tried a case structure where the running time will be displayed when condition met=true.
The problem is, I want to record onscreen, (and hopefully to a text file) only the first time at which the condition is met- not have the time display when the condition is met.
The rest of the VI needs to continue running, and I only want the first value from the timer at which the condition is met.
Any ideas?
-Adam
(2,144 Views)
Is your data stream constant? As an example constant sample rate. If this is the case you can keep track of the total numper of sampels recieved. Say i have a constant data stream sampled with 100Hz. If an event occur at sample 566, I can track this event to start time+(566*0.01) sec. This method use almost zero CPU since you only work with a single integer. Use a shift register for this purpose
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,115 Views)
