09-26-2014 01:18 PM
I’m using the Solartron1255 with the drivers of sosl1260 (of course they are not 100% compatible, because 1260 has more options and features, but they should work, according also to many posts about this point).
I'll try to provide as much information as I can, so below I'm posting screenshots of the front panel and block diagram of the VIs generating the error:
After recycle (or multiple) mode measurements, I try to ReadMultiple.vi as shown in the figure below :
I have the following error when trying to collect the data : Error - 1073807339
When going into the block diagram of ReadMultiple.vi (please see below) , we notice that the error occurs at the Wait condition.vi
The figures below show the block diagram of the WaitCondition.vi with and without the error as well as the stage where the error occurs.
Measurements configurations and hypothesis tested:
Any suggestions are greatly appreciated.
I must admit that I am a beginner on labview and if you require any further information, I will try my best to provide it.
Thank you !
09-26-2014 01:34 PM
03-03-2017 11:34 AM
HI!!!
YOU CAN TRIE THIS:
INSERT A "FLAT SEQUENCE" BEFORE THE "READ SINGLE" VI, INTO THIS "FLAT SEQUENCE" DO YOU ADD "WAIT” VI WITH ONE SECOND AND THE NEXT SEQUENCE DO YOU CONTINUATE WHIT THE REMAINING VI.
SORRY, FOR MY BAD INGLISH.
03-03-2017 02:24 PM
Let's turn down the volume on that message.
Juan, your CAPS LOCK key is stuck!
04-26-2023 08:57 AM
Could you solve this issue?
