Counter is a chip on a physical board, that actually generates the timing pulses.
Create a constant, it will show available counters if any
You can also create software 1 kHz timing source using a "Create timing source" function from Timed structures palette. I can not imagine why you would need hardware triggered timed source not on real-time system.
