05-05-2014 12:29 PM
I am using the get time/data and format date/time string to write a running log of my while loop time while my program is running. The problem is the text file has the time written in this format: 12:26:13 -0.000000, where did these zeroes come from and how do i remove them? If i hook up an indicator to the time strring output I do not see them only the time but there it is written once i open up the file.
05-05-2014 12:34 PM
Assuming you are viewing the file in Excel, it will choose a format to display a date/time field (not necessarily the format you desire). If you open the file in a text editor, it will probably be displayed as you told it to be displayed.
05-05-2014 12:37 PM - edited 05-05-2014 12:39 PM
nevermind i totally missed that a tab and was adding my next string value to this one.
05-05-2014 12:43 PM
What format string are you using?
