08-25-2015 07:13 AM
I am writing below 2 d array to write spreadsheet VI .But when opened the spreasheet I couldnt able to find the milli seconds.Please.
1.Attached the 2 d array,
2.Block diagram.
3. spreasheet view
Solved! Go to Solution.
08-25-2015 07:28 AM
This looks like it is just Excel playing format games with you. Open the file with a text editor. Is the miliseconds there? If so, then you just need to change the format of how Excel is displaying the timestamps in those cells.
08-25-2015 07:36 AM
Hi Crossrulz,
Yes..I edited in notepad and its shows me the milli seconds values.
Also ,I tried with some excel formats to display time stamp with milli seconds value,but doest get anything good solution from internet.
Any idea on the excel format to dislay the milli seconds? please assist
08-25-2015 07:53 AM - edited 08-25-2015 07:56 AM
I just did something like this...
08-25-2015 08:26 AM
I'm sure you figured it out if you tried Crossrulz' suggestion, but if you want all three decimal positions, you need .000 in the Excel format string.
08-25-2015 10:01 AM
Hi Guys,
Yes.I got it with the format suggested.
Thanks.
Dskp
08-25-2015 10:24 AM
It helps if you mark Crossrulz' post as the Solution (it both gives him credit and tells others with the same question where to go to find the answer).
BS
