Time stamp comparison for every day. confusion
Hi, I am trying to compare two timestamps and then going to create a case structure, as far as simple comparison goes it seems ok and easy but actually I want to compare every day or in other words I need the VI to start the particular task every day while running at the given time which means the time will remain fix but the the value in timestamp contstant/control should change automatically to next day.
For example if I put 7-04-2011 1pm .. it just not compare for 7th April but i need it to compare everyday like 8,9,10...april as far as vi is running and every day the task should execute at 1 p.m. I hope the issue is clear and i'll get some useful suggestions.
Naqqash
Naqqash
(5,762 Views)
Post your vi what you have did so far...
(5,759 Views)
Thanks for reply. Here it is.
Naqqash
(5,751 Views)
Accepted by topic author Naqqash
Hi Naqqash,
your type of comparison will fail on computers with other regional settings...
Better try something like that:
(German LV: Stunde=hour...)
(5,743 Views)
Danke Schön. Smiley Wink  So stupid of me never thought to unbundle the time cluster anyways thanks alot. Only the top part of the program is suffiecient for comparison no need to use format string and then concetenate (might be useful for others in future).
Naqqash
(5,734 Views)
This little baby is actually in my image gallery somewhere... the subject "time to time of day" comes up quite frequently.
"Should be" isn't "Is" -Jay
(5,701 Views)
