09-15-2009 03:37 PM
What do I need to change or add in my block diagram so that on the waveform graph the time will be on the x-axis instead of the data points. I am running this VI on a pda for some testing and I would rather get the time on the horizontal axis. Im also using an NI USB-6008, windows xp and Labview 8.2
09-15-2009 03:44 PM
09-15-2009 08:27 PM - edited 09-15-2009 08:28 PM
And since you are sending it an array of doubles rather than an array of waveforms, there is no timin information associated with it. It will assume 1 sample per second. If your acquisition is faster than that, you will need to set the dT of the graph or the scaling multiplier factor of the X scale of that graph.
(PS, it is always a good programming practice to show the labels for all the terminals on your block diagram and assign the terminal a name.)
