02-21-2017 12:41 PM
Greetings!
I need to display the time on my chart to the proper current system time on the X-axis. I've tried different settings in the properties to no avail. Also, can someone please assist in telling me why I'm getting a "blip" in my chart data every x-amount of seconds (see front panel image). I'm running the VI with hardware connected. Adjusting my samples to read or rate in the task does not remedy the problem, so I know it's not that.
Thank you,
D
02-21-2017 12:57 PM
OK, it appears I have to set the samples to read pro-grammatically, as it appears to ignore the samples to read in Max. So that fixes one problem. Still trying to fix the original problem of this post - the date/time on the x-scale.
D
02-21-2017 05:21 PM
Try using the build waveform bundle. If this doesn't work, then try using an XY graph.
