12-30-2015 10:44 PM
i have a set of values (0-359). According to each interval i have to give the each set of value (0-359) to trigonometric functions. i am setting the interval. Is there a way for it?. Can i use cluster(for set of values) and timer for the interval?
12-31-2015 12:30 AM
12-31-2015 12:42 AM
No i am not generating any waveform. i am entering these values (0-359) . it is an angle degrees. corresponding to each degree of angle i need to get the sin/cosine of the angle what i am giving. the interval can be (1/360), (10/360). by these interval values i need to increment the angle degrees. then i want generate the sine/cosine of that angle.
12-31-2015 01:16 AM
12-31-2015 02:07 AM
i am incrementin the angle by some intervals, instead for the incrementing purpose can i use timer for that.
12-31-2015 03:26 AM
01-03-2016 10:58 PM
Thanks Mr.Dennis_Knutson,
Can you help me how to use the ramp pattern to create the array and a for loop. Can you give me an example
01-04-2016 12:52 AM
