Threshold detector
Is there any VI performing a Threshold detection?
I'm not satisfied with the "Peak detector" vi results, because no
hysteresis can be defined. In my application the lenght of peaks is very
variable so it's difficult to use a "widh" value that matches all peaks.
The threshold detection should work exactly as a Schmitt Trigger. and
return an array with the trig index locations.
With LabView 6. there is a "Basic Level Trigger Detection" but it only
trigs once.
Thank you very much.
(2,699 Views)
I'm feeling a little generous today. If you post a VI containing a sample data set with peaks (get the data into a control or indicator, Make Current Values Default and save), I'll see if I can't whip up a peak detect VI with hysteresis for you.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(2,698 Views)
Thank you. I think I can write the vi by myself. I was just surprised not
to find a threshold detector VI already written. Threshold detection
should be a very common problem. I just didn't want to do the job if I
there were already an existing VI to perform this detection.
Photon Dan wrote in news:50650000000500000040080100-
1042324653000@exchange.ni.com:
> Daniel L. Press
> PrimeTest Corp.
> www.primetest.com
(2,698 Views)
I was wondering if you did develop the threshold dectector and if so are you willing to share?
Mark Mutton
Electrical Engineer
(2,580 Views)
