NI Home
Cart Cart | Help
You are here:
Reply
Member
ssnp
Accepted Solution
Third party dirver in distribution application
I am not sure how to add Third party dirver in distribution application in LV11 service pack1.
Trusted Enthusiast
TiTou
Re: Third party dirver in distribution application
There are different ways, one that I use successfully in the past is to include the third party driver in the project, include it in your installer and use the "run after install" (I can't remember the exact name of this feature and being at home on my mac I can't check because LabVIEW mac can't build installers) option to launch the installer.
Other ways would require more work I think, have look here.
I've look a bit but I couldn't find a good (and recent) white paper about this on NI Knowledge base... can someone find a good white paper?
Hope this helps
________________________________________________________________
"Cambiar el mundo, amigo Sancho, que no es locura ni utopía. sino justicia."
Cervantes
Active Participant
DianeS
If you have more than one third-party driver installation, you can also write a batch file to call them, include the batch file in your project, then use "Run executable after installation" (see image below) to launch the batch file, which in turn will launch the installers for your third party applications.  You can also use the batch file to install any support files, .ini files, etc. that your application might need.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
