03-24-2013 09:07 PM
I'm not sure how to fix this error. I have attached a screenshot. If anyone can help right now it would be much appreciated.
Error message: The version of this library downloaded on the target does not match the version in the project. All VIs and Libraries will be closed if you choose to apply and continue with deployment.
Kaleb
03-25-2013 12:14 PM
Hi Kaleb,
This message simply means that you have updated something in this library since the last time you deployed it. The library remains deployed to the target even if you don't currently have a program running on the target. The message is warning you that you have a library of the same name saved on the target and if you deploy this new library to the target any VIs or Libraries currently running on the target will be stopped in order to allow the library to update. This should not cause you any issues as long as you do indeed need want to update these VIs, variables, or whatever else you have contained in the library. All you should need to do is hit Apply.
I hope that helps!
