The temperature control programming for T95 controller
I want to control temperature T95 controller using labview program.kindly provide suggestions
(2,905 Views)
Duplicate - http://forums.ni.com/t5/LabVIEW/linksys32-software/m-p/3135844
You really need to do better than just say T95. If you have a manual that explains the remote control options, attach that.
(2,882 Views)
hi, i am attaching manual for t95 controller
(2,846 Views)
You can use MAX or a program such as potty to test the connection and port settings. In MAX, you would set the termination character to be a carriage return and send T\r where \r is the carriage return. Do a read and verify that what you get is the response detailed on the manual. Once that works, it's s master of impending the command you needed and parsing the response.
(2,834 Views)
