The meaning of icons on LabVIEW welcome screen
Hello~
I think the first icon from left side meant the PC have been installed "Real Time toolkit", and the second is "Vision debelopment toolkit".
How about the third icon? Is it Mathscript toolkit?
Is there a source code for "Welcome.vi" for this function? If yes, could someone provide the path to me?
Thanks a lot. Steve
(3,481 Views)
Hi cn,
to check the meaning of those icons you could check your "NI License Manager"…
(3,462 Views)
Accepted by topic author Stephen886
I think this shows the modules you have installed, although I'll admit to never looking closely.
Here are some possible options:
  1. Open the same window from the Help menu>>About. If you then hover over the icons, it looks like you get the description of each (at least for the one I have installed here).
  2. Open the NI license manager and look at which modules you have for each LV.
  3. Open the software section in MAX and look at what you have installed. I'm not sure how detailed this section is and whether it shows relationships (probably not).
___________________
Try to take over the world!
(3,460 Views)
Did you try hovering your mouse over it to read the text that shows up when you do?
(3,426 Views)
Hello all,
Thanks for the reply so quickly, actually this is a question from another forum and I just want to help answer the guy. 🙂
I will reply the answer later to the forum.
I like this answer, because you guys provided the method instead of telling me what the toolkit actually is.
(3,405 Views)
