I am trying to use the Quotient & Remainder function from the Numeric palette within a timed loop to initiate data logging at an interval that is a multiple of the loop time; however, it doesn't work because the remainder output is not always correct. The two attached LabVIEW code snippets demonstrate this problem. The remainder output should be calculated identically in both examples but they are sometimes incorrect in each and don't even agree with each other.
I have used this technique before with older version of LabVIEW, even with LabVIEW 8 but not in a timed loop, and all worked fine so am I doing something wrong within the timed loop or is this a bug with LabVIEW 8?
