01-24-2011 01:29 AM
I'm using TestStand UI ExpressionEdit Control in my UI.
I want to get the value change event on this control.
I have created an Event case with value change for this control, but unfortunately I am not getting the value change event in my event structure.
Does anyone know what can be the reason?
Am I missing any setting which needs to be done on this control?
Can anyone help me with a solution?
Thanks in Advance...
01-24-2011 02:53 AM
Hi Maverick,
Have you had a look on the TestStand Operator Interfaces examples delivered with TestStand?
If you look at the SimpleOI example, you will see an implementation of Callbacks for handling TestStand ActiveX Controls Events. Those callbacks are called and can create a user event programmatically, wich will trigger your event structure.
Kind Regards,
Olivier L. | Certified LabVIEW Developer
01-24-2011 07:24 AM
Hi Maverick,
I tried using value change on ExpressionEdit, and finally came to know that Value Change does not work for this control. I discussed this with NI, and they gave me a work around for this, which, was not helpful for me though.
To carry out something similar, what I do is get what I type in ExpressionEdit control using property node, and trigger some event when I have typed some string in this. Its kind of polling the control, which is not efficient.
-FraggerFox
01-24-2011 10:43 PM
Hi Oliver,
Thank you for reply...
I was unable to find a suitable example that you have mentioned.
Can you please send me one example which explains the solution. Or the name of the example and the version of TS.
Thanks in advance...
01-25-2011 01:33 AM
Hi Maverick,
You can find the exemple in C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2.1\UserInterfaces\Simple\LabVIEW (for Windows XP)
In this exemple, it uses a "Quit Application Event" user event, with the "Exit Application" Callback.
But I'm not sure what kind of callback you can obtain for your UI Expression Edit, I didn't pass enough time on TestStand yet.
01-31-2013 02:12 AM
Hi Maverick,
Did you find any solution for this problem?
I am facing the same issue.
Thanks and regards,
Aditya CHANGAVALLI
LabVIEW 2009 SP1
TestStand 4.2.1
