Temperature units task property not working as expected
Using labview 2013, daqmx. NI9213 module. We have created the TASK, created 16 virtual channels, set the thermocouple type to J and units to Fahrenheit by writing to the respective Task property nodes, then we use the start daqmx and subsequent daqmx reads but the daqmx read only returns the temperature in Celsius regardless of the setting in Deg F or Deg C using a constant wired to the Task property node. I tried Deg Kelvin but it bombs with a runtime error. Does setting the Units to Deg F do the conversions and return the temperature in Fahrenheit or do I need to add a scale property too? Or just do the conversion from C to F math on the result?
(2,747 Views)
Can you post your codes or a screenshot to see how you are implementing this?
(2,698 Views)
Here is a snippet of a working 9213 task scaled to Deg F using 8 K type thermocouples.
If you want. Drop it on a BD and right-Click- Generate code>>Configuration and you'll likely see where you are configured wrong.
"Should be" isn't "Is" -Jay
(2,692 Views)
