06-15-2015 11:38 AM
Hello Everyone,
I am trying to capture a waverform from TDS 2004 C oscilloscope using USB interface. I have downloaded the device drivers (LV 2014) from ni's website. The program gives the followning error message
(Hex 0xBFFF001D) The specified attribute is not defined or supported by the referenced resource.
I have noticed that in the initialze subVI, there a case structure that has only control for GPIB and serial communication. Does anyone know the solution to this problem?
-Hamza
06-15-2015 12:30 PM
06-15-2015 12:51 PM
Yes the instrument appears as USB0::0x0699::0x03A2::C012687::INSTR, I have used the same address as visa resource name. If you check the VI I attached with my previous message, it only has true and false cases (true for serial and false for GPIB/USB). The error appears after second case structure and inside the third one (Reset Instrument/Default Setup).
Thank you for your help.
-Hamza
06-15-2015 01:29 PM
The comes from the first case structure.
06-15-2015 03:04 PM
06-15-2015 03:16 PM
Sorry for the confusion, I have attached the screen shot of block diagram. Even though I select USB as interface type, it still selects Serial code in the first case structure (causing error code).
06-15-2015 03:22 PM
06-16-2015 10:25 AM
No it was on serial but I am not using serial port therefore I changed it to USB.
06-16-2015 12:06 PM
