12-01-2015 02:21 PM - edited 12-01-2015 02:28 PM
Helo there, need help controlling the Tekpower 3645A power supply. Anybody has sample code that can share with me? I downloded the drivers for the Array Electronics 3645A but it is not working. Anybody can help? The power supply works because I installed the software that comes with it and I was able to make it work, but my application requires labview to controll the power supply instead. Thanks!
12-01-2015 02:58 PM
12-01-2015 03:45 PM - edited 12-01-2015 03:49 PM
It says that Visa timed out. Yes I am using the example that comes with the drivers. The communication is USB to RS232.The example code I am using is the one below. Also de communication protocol is attached below for this power supply. Thanks!
12-01-2015 05:55 PM
12-02-2015 06:45 PM
Hi Chulito,
Would you mind taking a look at Steps 7-9 in the document linked below? I am hoping that clears up the issue.
Instrument Driver Troubleshooting Guide
12-03-2015 04:32 PM
Hi Cicco thanks for your help, I was able to make the Tekpower 3645A power supply work following your instructions, really appreciate it. All I did was Tools>>Instrumentation>>Find instrument drivers>>
Then on the Manufacturer drop down window I selected the Array Electronics>>Then right click on search button to find the drivers>> Then installed drivers>>Lastly restart my computer. The pictures below show what I did to install this drivers.
Thansk and have a great day!
Isidoro Vazquez
12-03-2015 05:05 PM
Excellent! Glad to have helped. Happy coding and designing!
12-03-2015 06:38 PM
12-03-2015 07:07 PM
@Dennis_Knutson wrote:
So, in your original post when you said you had downloaded the driver, you hadn't actually downloaded it?
He might have meant the vendor's software and not the LabVIEW drivers.
English apparently isn't his first language.
12-04-2015 07:31 AM - edited 12-04-2015 07:33 AM
Good morning Dennis, I thought I did but I had not properly. Actually this is the first time I do something like this and beforehand I want to apologize for the misundertanding I may have caused you. I really appreciate you taking the time to reply to my question and as it is mentioned, English is my second language and many times is very hard to come up with the proper question. But I really appreciate your help and the help of everyone else.
Thanks and have a great day,
Isidoro Vazquez
