I would like to shift some bits to a shift register. This requires that I set up a multi-line digital pattern (I need a clock, my serial data, some enable/disable lines, etc.) Basically I'm trying to build a timing diagram in labview. I can do this piece by piece but it doesn't seem elegant.
Can someone point me to a more streamlined solution? I haven't dealt much with DAQMX and hardware shift registers using labivew. All feedback would be appreciated!
