12-20-2014 01:27 AM
Hello Folks,
Im trying to take snapshot of live stream in VLC, this operation happens very often so i wanted to do it in background.
Basically i have connected and PoE camera and using VLC player - Network stream, I could be able to stream live.
Now how can i take snapshot using labview and VLC player in minimized position. Thanks in Advance!!!
12-20-2014 05:59 PM
Do you have any code (that works)? It seems that VLC is a product that is not part of LabVIEW -- there are mentions of it on the Web with some discussion of how you might be able to do things in LabVIEW. What are you trying to do? Why use VLC? What have you tried?
BS
12-20-2014 11:16 PM
Hey BS
Thanks for replying
Right now im Maximizing VLC application and doing Printscreen and then Minimizing VLC all using LabVIEW code. But when i maximize, VLC will pop up on the monitor which is not good for repetitive action of taking snapshots. So VLC should run in background and take snapshot when labview triggers.
12-21-2014 11:20 AM
It is extremely difficult to help someone with their LabVIEW code when we can't look at the LabVIEW code. It appears, from your description, that you use LabVIEW to start VLC, then use LabVIEW to maximize the VLC window (which allows you to manipulate its User Interface and take pictures), then minimize the window (which hides VLC's User Interface).
It would be helpful to actually see if this "guess" is what you are doing, or if you are doing something else that may suggest a way you can accomplish your task. Otherwise, if we have only a vague idea what you are trying to do (and how you are trying to do it), we can only give you a vague answer for why it isn't working.
Post your LabVIEW code.
BS
12-21-2014 12:01 PM
Your best bet is posting on the VLC forum to see if VLC has a sanpshot function.
Normally you can't take a snapshot on a minimized window in any programming language.
12-22-2014 09:48 AM
You may have to use a little Google-Fu
https://forum.videolan.org/viewtopic.php?f=13&t=115070
http://askubuntu.com/questions/179890/haw-can-i-take-snapshots-from-a-live-stream-in-command-line
