Tabs not matching Enum
Good evening,
I'm a bit perplexed by something that's probably incredibly easy....
I created a tab structure, and added a third tab.  Each tab was uniquely named.  I then went to the block diagram to use the associated enum control as the input to a Case structure.  The thing is, there were three uniquely named tabs, but the case structure only showed two options.
What have I missed that would make the third tab name appear?
Thanks!
(1,946 Views)
Accepted by topic author gpsmith
New case structures default to two cases. Right-click the case structure and "add case for every value".
(1,941 Views)
Thanks!  Knew it was something obvious 🙂
(1,935 Views)
