03-19-2014 06:39 PM
Good evening,
I'm a bit perplexed by something that's probably incredibly easy....
I created a tab structure, and added a third tab. Each tab was uniquely named. I then went to the block diagram to use the associated enum control as the input to a Case structure. The thing is, there were three uniquely named tabs, but the case structure only showed two options.
What have I missed that would make the third tab name appear?
Thanks!
03-19-2014 06:41 PM
New case structures default to two cases. Right-click the case structure and "add case for every value".
03-19-2014 06:43 PM
Thanks! Knew it was something obvious 🙂
