12-22-2016 01:49 PM
I use a tab control with invisible tabs to display two pages of information. I have a button on each page to switch between tabs. Looks great and works well. Except there is a tab control value change event case that initialises some things on the each page. The value change event is handled if I make the tabs visible and click on them. It is not generated when I programatically set the value on the button click event.
Any ideas what is going on there?
Solved! Go to Solution.
12-22-2016 01:55 PM
Solved. Needed to set the Value(Sgnl) property, not the Value property...
12-22-2016 01:58 PM - edited 12-22-2016 01:58 PM
Without seeing your code, I can only guess. When you set the value of the tab control, use the property node for value(signaling).
Oops. Late reply
