You asked,
I was going to try and defer front panel updates to save some cycles.
This may not be required if they are just booleans. I believe it was LV 7.0 or ther-abouts were the defer FPupdate forced an extra screen up when when went T.
When using a tab control with say 5 tabs, each with indicators on them - even though you can only be on 1 tab at a time...are all the indicators on all the other tabs still being drawn?
Oh no. That would be terible. They are only rendered if the tab is being viewed or when you switch to a tab.
All those other tabs boolean values should still be being updated...I guess thats what I'm looking to stop.
If their terminal, local, Value, or Value Change are written, they will be updated. The "value" is kept behind what you see on the GUI and is protected using the UI thread (exception terminal and locals which use special techniques).
Ben
