TWO VI'S
I have TWO vi's. VI no. 1 and VI no. 2. How does LV know which VI to execute? How do I write a program to choose between the two vi.s. I understand I must use ENUM. The LV is attached.
(2,354 Views)
I don't fully understand your questions.
LV knows which VIs to execute, because you placed them on the block diagram.  If they're on the diagram (without any overlying structures), they'll be executed.
If you want to be able to programatically choose which VI gets run, you place a "CASE" structure on the diagram and drop one VI into each of the "TRUE" and "FALSE" cases.  Then by wiring a boolean variable to the case, the executing VI will be chosen.
Have a look at the LV examples.  This is pretty basic stuff.
ENUMs are definitely not requred.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,350 Views)
Can you post some examples that uses the ENUM?
(2,347 Views)
Using an enum is the same as using the boolean.
Just place an enum control on the front panel, fill in some values and wire it to a case structure. The structure will change the selector values to the values of the enum.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,342 Views)
"Can you post some examples that uses the ENUM?".
No, I don't think I can.  I just wrote that Enums aren't required for this.  In fact Enums in themselves have nothing to do with your original question.
What examples are you looking for?  I need to know what you mean before I can give examples.....
Shane.
(2,335 Views)
