09-26-2010 12:53 PM
Dear all!
I'm using the following vi. to save data coming from two different channels in a TDMS file. In my main application, I have two bottons, one for starting the recording of the data and the other for stoping the operation. Whenever I press the record button, this TDMS write vi. is called and it stops executing when I press the stop button. Could anybody tell me how could I save the exact time when the recording of the data is stopped?
I would really appreciate your help,
Thank you very much in advance,
Miren
09-30-2010 06:03 AM
Hi.
I present you two ways to do it. Both are included in the vi.
1. The Timestamp of the signals ends can be calculated from the Signal data : t1 = t0 + dt * NumberOfSamples
2. Or use the (less exact) PC timer (see vi) and save it to the tdms file
Greets CtheR
