10-17-2012 03:15 AM
HI,
I'm doing a project in labview , the below are the few details of the project.
1) Embedded Controller (Ni PXI 8106) is connected to a Machine. This controller acts as a server, the server code is written in cvi. The tdms files which are gathered from Machine is stored on this embedded controller (server).
2) Pc with Labview which acts as a client .
The task is to access the Controller using TCP/IP from labview programme (client) and to get tdms data or channels and plot in labview.
So how do i start to program the client? or If there are any examples wrt accessing tdms files on server and then plotting in labview, pls do post?
10-17-2012 04:33 AM
Kindly stick to a single thread. Somebody will post a reply and help you out there if you keep all your similar queries tracked in a single thread.
Mathan
