06-15-2009 10:33 PM
Please help me figure this out. I have a Sorenson Power Supply connected to a 8 port hub and I have configured the device as a VISA TCP/IP port. I have validated it using the "Validate" button under MAX but when I try to use the LabVIEW drivers and the TCP/IP VISA alias, I get a communication error.
The power supply requires a username and password to login to its web server but I am not sure if this is required for the device to work under VISA but it kind of makes sense otherwise anyone on the network could set the power supply. Could this be my problem? Anyone with a solution? Thanks in advance.
Michael
06-16-2009 02:08 AM
Hi Michael,
do your Power Supply only support the web interface? Do you try to automate what you normally do with your webbrowser?
Mike
06-16-2009 09:39 AM
The power supply should be able to communicate via VISA TCP/IP. I can set up the connection/device in Measurement and Automation (MAX) and I can "Validate" the connection so I should be able to talk with it via VISA. I have opened the VISA panel in MAX and tried to do the "IDN?\n" command but I get a timeout error. There must be a permission or security setting that has to be flipped but I do not know which one and where it might be located.
Michael
06-16-2009 03:17 PM
Hi Michael,
What's the model of your power supply? Have you tried looking in the supply's user's manual to see if there's a setting you need to change to communicate across TCP/IP?
06-23-2009 08:03 PM
Hello Justin,
I am using a Sorensen DCS40-75e model. Right now, I can talk across TCP/IP using a web browser and logging in and supplying a password. I can set everything in this mode but I want to incorporate this into my LabVIEW software. I have talked with Sorensen which is owned by Elgar. Apparently, they had an outside contractor create their LabVIEW drivers and no one at the tech support knew anything about LabVIEW. Kind of unfortunate. My current options are to try to plug along and find a solution using ethernet or use RS232 and have no problems except making an serial cable with an RJ45 jack on one side and a D-Sub 9 pin on the other. If anyone has a suggestion, I will be glad to try it and report the findings here. Thanks.
Michael
06-23-2009 11:03 PM
07-25-2013 09:01 PM
Hi, sorry to bring this thread back up, but did this issue ever get resolved? I am having the exact same issues as you, but with the Sorensen DCS60.
